If the search function described in the previous section fails to detect a third-party application that has been successfully installed (on the computer where Switch is installed), you can manually locate the application through the context menu offered by the Flow Elements pane (as shown in the previous section).
Be careful with this procedure; selecting an unsupported application will have unpredictable results.
To manually locate a third-party application corresponding to a configurator:
Some configurators do not offer this function.
