Adding a connection
To establish a new connection to a copy of PowerSwitch/ FullSwitch on your local network:
  1. Press the + button at the bottom; a new line appears in the list with status "Unknown Server".
  2. Complete the fields in the rightmost section; see table below; also see Preparing to run SwitchClient.
    Field
    Contents
    Host name / IP address
    The host name or IP address of the computer on which PowerSwitch/ FullSwitch is installed
    To connect to a copy of PowerSwitch/ FullSwitch on the computer, enter "localhost" for this field
    Port
    The network port on which PowerSwitch/ FullSwitch expects client connections (usually the default value of 51008)
    User name
    User name as recognized by PowerSwitch/ FullSwitch (see Preparing to run SwitchClient)
    Password
    Password as recognized by PowerSwitch/ FullSwitch (see Preparing to run SwitchClient)
  3. When all information is entered correctly, the status underneath changes to Connected
  4. If SwitchClient fails to connect, refer to Preparing to run SwitchClient and setting up communication. After rectifying the problem, check or update the Connections panel again.
