Merge PDF Pages is a processor that produces a single PDF file containing all of the pages provided by the PDF files in the incoming job folder. The tool does not require Adobe Acrobat or any other external application to be installed.
The keywords for the Merge PDF pages element are:
Merge PDF Pages allows only a single outgoing connection
Name |
File, Title, Author, Subject and Keywords will be merged if all input PDF files have the same value. So in case a flow uses a Split PDF and Merge PDF tool, this metadata can be restored. If the metadata has different values, the merged PDF will have empty metadata fields.
The Merge PDF tool processes a job folder, so Switch metadata is derived from that folder and not from the individual PDF files.
The merged PDF will have the highest PDF version number. Example: Merge two files, one PDF version 1.4 and the other PDF version 1.6, the result will be PDF version 1.6.
The tool will merge the files in increasing alphabetical order of file name.
However, if
every file name contains at least one number and
every file has the same amount of numbers (consecutive digit groups) in their file name,
the Merge Order processor will take the lowest number represented by any of the digit groups in the file name as "Rank". If no two files have the same rank, the processor will merge the files in order of increasing rank.
More advanced merge ordering can be achieved by using the Sort files in job tool in front of the Merge PDF pages tool. See Sort files in job.
The Merge PDF pages will correctly collate all of the examples provided for the Split PDF in Pages tool (see Split PDF in pages)
