Licensing
From the About Enfocus Switch window, you can:
For easiest configuration, the machine running your copy of Switch should be online with full Internet access while performing licensing tasks.
However, if the machine you are using does not have full Internet access, you can perform licensing tasks off-line if you:
Before you can activate or deactivate licenses, you should set up an activation account using the Enfocus website (http://www.enfocus.com/CreateAccount).
Contents
