XML pickup
XML pickup is a processor that allows associating an arbitrary XML file with a job as metadata. It supports the following pickup mechanisms:
For more info see Pickup mechanisms.
Keywords
Keywords can be used with the search function above the Flow Elements pane.
The keywords for the XML pickup element are:
Data model
The metadata source must be a well-formed XML file with any schema. The dataset data model is XML.
Connections
XML pickup allows only a single outgoing connection.
Properties
Property
Name
Dataset name
A name for the set of metadata picked up by this tool; see picking up metadata
Pickup mode
The pickup mechanism; one of:
  • Metadata alongside asset
  • Metadata in job folder asset
  • Metadata refers to asset
  • Metadata is asset
See also Pickup mechanisms
Additional properties are shown depending on the selected pickup mechanism; see the description of each mechanism for more information.
