SOAP class
Background
The SOAP communication protocol and the Web Services framework provide a standard mechanism to communicate between applications and more precisely to request the execution of a particular service in a different application (a "remote procedure call"). The communicating applications may be running on the same computer, on computers in the same local network or on remote computers across the Internet.
For more information see http://www.w3.org/TR/SOAP/.
Overview
The SOAP class supports a subset of the SOAP 1.1 communication protocol over HTTP. Specifically, it allows remote procedure calls to be made to a remote server. The SOAP protocol is used to marshall JavaScript parameters to a remote procedure call and to unmarshall the result as a JavaScript object.
The current implementation has the following restrictions:
Class instances
The send and request methods - which were already available in older Switch versions – are static functions which allow sending of a simple SOAP message without headers. As they are static functions, there is no need to create instances of the SOAP class.
For more direct control an instance of the SOAP class may be created. This represents an entire SOAP request and/or response message including body, headers and envelope.
Static Functions
request( url : String, request-object : request-object, action : String ) : response-object
Initiates a remote procedure call (RPC) or sends an XML message to a SOAP HTTP endpoint, waits for the endpoint to reply (synchronous processing) and returns its response.
An exception is thrown if the request object does not conform, when the SOAP endpoint returns a SOAPFault or when there is a failure from the underlying HTTP transport layer.
send ( url : String, request-object : request-object, action : String )
Initiates a remote procedure call (RPC) or sends an XML message to a SOAP HTTP endpoint without waiting for a reply.
An exception is thrown if the request object does not conform or when there is a failure from the underlying HTTP transport layer.
Constructing
SOAP ( )
Constructs a new empty SOAP request.
SOAP ( request-object : request-object )
Constructs a new SOAP request and sets the SOAP body
SOAP ( in-path : String )
Constructs a new SOAP request and reads the SOAP envelope from the specified XML file.
Property accessing
isResponse ( ) : Boolean
Returns whether the SOAP message is a SOAP response.
getBody ( ) response-object
Returns the SOAP body from the SOAP message.
setBody ( request-object : request-object )
Sets the SOAP body to the SOAP request. The body is replaced with the new body and the headers are preserved.
getHeader ( ) : header-object
Returns the SOAP header from the SOAP message.
setHeader ( header-object : header-object )
Sets the SOAP header to the SOAP request. The body is associated with the new header and the body itself is preserved.
Sending messages
requestMessage ( url : String, action : String ) : SOAP
sendMessage ( url : String, action : String )
Logging and debugging
writeToFile ( filename : String ) : Boolean
Writes the SOAP message envelope (including body and headers) to an XML file
Working with attachments
Data exchange is widely used in Web Services word. SOAP message is convenient to exchange with text data, but not convenient when exchanging large amount of data or when data is in binary format. For such purposes SOAP protocol provides ability to attach additional data to SOAP message. Switch SOAP class supports two types of attachments:
addAttachment(file-path : String, id : String, type : String, chunk-size : Number)
add attachment to message specifying the file name, attachment id and type values, chunk size is not used and reserved for future use, should be 0
getAttachmentsCount() : Number
return number of attachments in the SOAP message
getAttachment(index : Number) : ByteArray
getAttachment(id : String) : ByteArray
return contents of attachment specified by index "inIndex" of attachment identifier "inID"
getAttachmentID(index : Number) : String
get attachment identifier, specifying attachment by index
getAttachmentType(index : Number) : String
return attachment type string
getAttachmentIndex(id : String) : Number
get index of attachment with the given identifier
saveAttachment(index : Number, file-path : String) : Boolean
saveAttachment(id : String, file-path : String) : Boolean
save attachment to the disk file
setAttachmentSendType(attachment-type : Number)
getAttachmentSendType() : Number
set/get attachment send type: 0 - DIME format; 1 - MIME format
Working with SOAP message body, retrieving information
Since SOAP message body is a text in XML format, it is convenient to gather information from it as from XML. There are some functions to work with SOAP message as with XML document:
parseBody(element-name : String) : String[ ]
returns array of elements' values specified with name equivalent to Document's evalToNodesList, getNodeValue, except that elements specified by name, not by XPath
saveBody(file-path : String, root-element-name : String) : Boolean
saves extract from SOAP body specifying root element into file on disk
changeElement(element-name : String, new-value : String)
set SOAP body element value
Contents
