Problem alerts
These preferences configure notification of a system administrator in case of execution problems.
Property
Send problem alerts to
A list of destination email addresses and body text for each alert message; information about the error is appended to the body text
Problem job arrives
If set to yes, send an alert when Switch moves a job into a problem jobs folder
Processing takes more than (minutes)
Send an alert if a job takes more than the defined time for processing. When set to 0, this option is disabled.
Mail server is down for more than (hours)
Send an alert when an email server cannot be accessed for the indicated time (0 means do not send alert)
FTP site is down for more than (hours)
Send an alert when an FTP site cannot be accessed for the indicated time (0 means do not send alert)
Folder is unreachable for more than (minutes)
Send an alert when a backing folder is unreachable for more than "minutes"
External process fails
Send an alert when a process other than folder fails (that is, its process is put in the "problem process" state)
Execution log was not finalized
Send an alert when Switch detects upon startup that the execution log was not properly finalized, indicating that Switch server did not orderly terminate (due to a software or hardware failure)
Alert if free disk space for application data is less than, Mb
Send an alert when the amount of free disk space for application data is less than the defined amount.
