Job group
These variables are Switch-specific. The third column indicates the scripting API function that returns the variable's dynamic value.
Variable name
Data type
Scripting API equivalent
Job.ByteCount
Integer
Job.getByteCount()
Job.EmailAddress
Text Indexed
Job.getEmailAddresses()
Job.Extension
Text
Job.getExtension()
Job.FileCount
Integer
Job.getFileCount()
Job.Hierarchy
Text Indexed
Job.getHierarchyPath()
Job.IsFile
Boolean
Job.isFile()
Job.IsFolder
Boolean
Job.isFolder()
Job.JobState
Text
Job.getJobState()
Job.Name
Text
Job.getName()
Job.NameProper
Text
Job.getNameProper()
Job.Path
Text
Job.getPath()
Job.Priority
Integer
Job.getPriority()
Job.PrivateData
Text
Job.getPrivateData()
Job.Size
Text
Job.UniqueNamePrefix
Text
Job.getUniqueNamePrefix()
Job.UserName
Text
Job.getUserName()
Job.FileCreationDate
Date
The creation date/time of the job file or folder as taken from file system
File(job.getPath()).created
Job.EmailBody
Text
The email body text in the email info associated with the job
Job.getEmailBody()
Job.NestedName
Indent=" "
Text Indexed
A list of indented names (including extension) for all files and folders in the job; by default each level indents with 4 spaces; on a particular level names are sorted alphabetically; see example below
The Indent argument specifies the string added for each indentation level (default value is 4 spaces)
Script that recursively iterates over job contents
Nested name example:
The variale [Job.NestedName:Prefix="-> ",Indent=". "] might be replaced by the following lines:
-> My job folder
-> . First.pdf
-> . Second.pdf
-> . Subfolder
-> . . Readme.txt
-> . Third.pdf
The following variables access a job's occurrence trail to provide information on the job's origin and on why the job was sent to the problem jobs folder. Each of the variables access the most recent occurrence of a particular type, as listed in the table.
Variable name
Data type
Most recent occurrence of type
Job.FailElement
Text
Failed
Occurrence.getElement()
Job.FailFlow
Text
Failed
Occurrence.getFlow()
Job.FailMessage
Text
Failed
Occurrence.getLocalizedMessage()
Job.FailModule
Text
Failed
Occurrence.getModule()
Job.FailTime
Date
Failed
Occurrence.getTimeStamp()
Job.Origin
Text
Produced
Occurrence.getOrigin()
