Existing functions
Job class
The getEmbeddedDataset() function offers an additional optional argument and additional semantics related to Certified PDF 2.
getEmbeddedDataset( writable: Boolean, cp2 : Boolean ) : Dataset
If the cp2 argument is false or missing, the function behaves as before. If the cp2 argument is true, the function returns a CP2 dataset if the backing file is a PDF file, otherwise it returns an XMP dataset. The behavior is summarized in the table below. A returned CP2 dataset adheres to all semantics of an XMP dataset. For example metadata fields from multiple sources are synchronized into a unified XMP data model.
When the getEmbeddedDataset() function is invoked on a job for the first time in a certain entry point, it returns a dataset of the type listed in the table below. If the function is called again on the same job in the same entry point, it returns the embedded dataset object that was created in the first call, ignoring the value of the "writable" and "cp2" arguments in the repeat calls.
CP2 Writable File format Type of dataset returned
False False Any Read-only XMP
False True Supported for update
Not supported for update
Writable XMP
Read-only XMP
True False PDF
Other than PDF
Read-only CP2
Read-only XMP
True True PDF
Other supported for update
Writable CP2
Writable XMP
Read-only XMP
Dataset class
The following functions offer slightly expanded semantics.
getModel( ) : String
Returns "CP2" for a CP2 dataset; otherwise behaves as before.
createDefaultMap( ) : Map
For a CP2 dataset, the "cp2" prefix (with corresponding namespace) is always included in the map, even if the underlying XMP does not define it (because if does not contain Certified PDF 2 metadata or because it uses another prefix). Otherwise the function behaves as before.
XMP data model
finishWriting( )
For a CP2 dataset, an appropriate Certified PDF 2 signature is written to the backing file, in addition to updating the XMP and CP2 data structures. These changes are affected through incremental save. Otherwise, the function behaves as before.
External datasets
Since external datasets can never have the "CP2" data model, functions applying solely to external datasets are not affected by this specification. Specifically, the model arguments in the Job.createDataset() and Job.sendToLog() functions do not support "CP2".
