Compress
Compress is a processor that places the incoming file or a job folder into a compressed ZIP archive. All files in a job folder are placed in a single archive. The archive is named as the incoming file or job folder with a ".zip" extension.
Keywords
The keywords for the Compress element are:
Connections
Compress allows only a single outgoing connection.
Properties
Property
Name
Compress
If set to yes, the files in the ZIP archive are compressed (the default behavior)
If set to no, the files are stored in the ZIP archive without compression, dramatically reducing processing time; this can be meaningful when speed is more important than size, or when the files will not compress well anyway (example: JPEG images) – but you still want a single archive containing all files
Use password
If set to yes, all created archives are password-protected
Password
The password used for protecting archives
