Apago PDFspy
This configurator drives Apago PDFspy 1.0. It is a processor that tells PDFspy to dump a number of statistics about a PDF file in an XML file, and then picks-up that XML file as metadata that gets associated with the PDF file's internal job ticket. The PDF file itself remains unchanged.
See Picking up metadata and Using metadata for more information on handling metadata in Switch.
Refer to the Apago web site for information on the third-party application required by this configurator, and refer to the PDFspy product documentation for details on the format of the XML file produced by this configurator.
Keywords
The keywords for the Apaga PDFspy configurator are:
Detecting the application
Detection mechanism
Comments
Automatic detection at startup
Uses information registered with the operating system when the application is installed
Searching from the elements pane
Same as above
Manually locating the executable
Select the executable for the command-line version of the application
Connections
This configurator allows only a single outgoing connection.
Installing and licensing Apago PDFspy
To install and license Apago PDFspy for use with Switch, follow these steps:
Properties
To help limit the size of the metadata XML file, the configurator provides properties indicating which types of statistics should be included. If all properties are set to "exclude", the configurator (through PDFspy) still produces a minimal set of basic file statistics.
The word in parenthesis at the end of each property's description is the PDFspy command line keyword corresponding to this property.
Property
Name
Dataset name
A name for the set of metadata picked up by this tool; see picking up metadata
Pages
In/exclude statistics on each individual page in the PDF file (pagedata)
Fonts
In/exclude statistics on typefaces used in the PDF file (fonts)
Color spaces
In/exclude statistics on color spaces used in the PDF file (color)
Images
In/exclude statistics on images contained in the PDF file (images)
OPI comments
In/exclude statistics on OPI comments contained in the PDF file (OPI)
Bookmarks
In/exclude statistics on bookmarks contained in the PDF file (outlines)
Annotations
In/exclude statistics on annotations contained in the PDF file (annots)
Links
In/exclude statistics on hyperlinks contained in the PDF file (links)
Actions
In/exclude statistics on PDF actions contained in the PDF file (actions)
Names
In/exclude statistics on PDF names contained in the PDF file (names)
Forms
In/exclude statistics on PDF forms contained in the PDF file (forms)
XMP packet
In/exclude a complete copy of the XMP packet embedded in the PDF file, if any, with the statistics (XMP)
