Running the PHP sample
Note: The procedure to set up a web server and enable PHP depends very much on your choice of web server and Operating System.  In what follows, we will give an example, but it is assumed the reader is familiar enough with web servers to make it work on their own system.
The PHP sample depends on some specific settings, which can be changed in the php.ini file.  This table gives an overview:
Setting Value Remarks
allow_call_time_pass_reference Off
always_populate_raw_post_data Off
arg_separator.input &
arg_separator.output &
asp_tags Off
file_uploads On
upload_max_filesize 2M Change this if you need to upload bigger files
post_max_size 8M Change this if you need to upload bigger files
memory_limit 128M
log_errors On
magic_quotes_gpc Off
magic_quotes_runtime Off
magic_quotes_sybase Off
max_file_uploads 20
max_input_nesting_level 64
max_input_time 60
register_argc_argv Off
register_globals Off
register_long_arrays Off
request_order GP
variables_order GPCS
safe_mode Off
short_open_tag Off
Note: Before running the PHP sample, make sure the subfolder ‘public’ is writable for the user running the PHP server.
Example: running the PHP sample on Mac OS X
Mac OS X 10.6 (Snowleopard) comes with a built-in web server with PHP.  However, PHP is by default not enabled.
To enable it, open the file /etc/apache2/httpd.conf. Locate the line,
#LoadModule php5_module        libexec/apache2/libphp5.so
Remove the leading hash (#), and save the file. A default php.ini file which matches our needs is already available, but it is disabled. To enable it, rename or copy the file /etc/php.ini.default to /etc/php.ini.
Now PHP is enabled, and we just need to copy the sample to the web server: copy the contents of the Samples/PHP subfolder of the SDK to /Library/WebServer/Documents.
As a final step, we need to enable the web server.  In the Mac OS X System Preferences, go to Sharing, and enable the Web Sharing checkbox. Open a web browser, and go to http://localhost/index.php.
