Operations
CheckConnect
Returns a reserved integer if a connection can be established, and the Switch Server is accepting SOAP calls. The HTTP username and password must not be set for this call.
SOAP method CheckConnect
Parameters None
Returns Integer param-1: reserved
CheckUserNameAndPass
Returns a reserved integer if the username and password, set on the HTTP layer, correspond to an existing Switch user. The username must be set to the Switch username, a semi colon, and the code “EN”: "<username>;EN".
SOAP method CheckUserNameAndPass
Parameters None
Returns Integer param-3: reserved
CloseConnection
Tells Switch that the information related to this client connection can be deleted.
SOAP method CloseConnection
Parameters None
Returns Integer param-4: reserved
DownloadFile
Downloads a job (file or folder) from a checkpoint.
SOAP method DownloadFile
Parameters String flowId: the ID of the flow in which the job resides
String checkPointId: the ID of the checkpoint in which the job resides
String jobId: the ID of the job to download
Returns Base64Binary inSubmitData: the zipped job
GetCheckPointName
Returns the name of the specified checkpoint.
SOAP method GetCheckPointName
Returns String checkPointName: the name of the checkpoint
GetCheckPoints
Returns the list of checkpoint IDs for the specified flow.
SOAP method GetCheckPoints
Parameters String flowId: the ID of the flow from which to get the checkpoints
Returns String list checkPoints: the list of checkpoints in the flow
GetCheckpointJobInfo
Returns information about a specific job. Only the information about jobs waiting in a checkpoint can be requested. See also GetCheckpointJobsInfo.
SOAP method GetCheckpointJobInfo
Returns JobStatus list jobInfo: a list with exactly one JobStatus element, containing the information for the job.
GetCheckpointJobs10
Returns the list of job IDs for the jobs waiting in the specified checkpoint.
SOAP method GetCheckpointJobs10
Returns String list jobIds: the list of job IDs for jobs present in the checkpoint
GetCheckpointJobsCount
Returns the number of jobs waiting in the specified checkpoint.
SOAP method GetCheckpointJobsCount
Returns Integer jobs: the number of jobs waiting in the checkpoint
Returns information about all the jobs waiting in a checkpoint. See also GetCheckpointJobInfo.
SOAP method GetCheckpointJobsInfo
Returns JobIdStatus list jobInfos: a list with the information for each job in the checkpoint.
GetFlowList
Returns the flow IDs of all the flow on the Switch Server.  This includes both active and inactive flows.
SOAP method GetFlowList
Parameters None
Returns String list flowList: the IDs of the flows
GetFlowName
Returns the name of the flow with the given ID.
SOAP method GetFlowName
Returns String flowName: the name of the flow
GetFlowState
Returns the state of the specified flow.
SOAP method GetFlowState
Returns Integer flowState: the state of the flow.  Possible values are: 1: the flow is stopped (inactive) 2: the flow is being started 3: the flow is running (active) 4: the flow is being stopped 5: the flow is invalid
GetJobLockStatus
Returns the name of the user who locked the job, or the empty string if the job is not locked.
SOAP method GetJobLockStatus
Returns String userName: the name of the user who locked the job, or an empty string
GetJobsAdditionalInfo
Returns the file type, size, modification date, and in the case of job folders the number of files for the specified job(s).
When using this function, you should always check the status member of the returned AdditionalInfo: if busy or failed, the data is not reliable.
SOAP method GetJobsAdditionalInfo
Parameters AdditionalInfoID list jobsId: the list of job IDs for which to get information
Returns AdditionalInfo list jobsInfo: the information for each job
GetJobsHeavyInfo
Returns the thumbnail icon, number of pages and dimensions for the job.
When using this function, you should always check the status member of the returned HeavyInfo: if busy or failed, the data is not reliable.
The stamp member of the returned HeavyInfo is used to determine whether the heavy info should be refreshed: if calling this function more than once for the same job, you should set it to the value last returned by the Switch Server, to prevent unnecessary calculations.
SOAP method GetJobsHeavyInfo
Parameters HeavyInfoID list jobsId: a list of job IDs and information required to get the heavy info.
Returns HeavyInfo list jobsInfo: the requested info per job.
GetJobsMetadataInfo
Returns the metadata for one or more specified jobs.
SOAP method GetJobsMetadataInfo
Parameters MetadataInfoID list jobsId: the list of job IDs for which to get the metadata
Returns MetadataInfo list jobsInfo: the requested info per job
GetLogData10
Returns log messages from the Switch Server.  Note that if there are a lot of log messages, this can take a long time. Because of that, lastTime should be chosen to minimize the number of messages to be returned.
SOAP method GetLogData10
Parameters String lastTime: the time of the earliest log that should be returned
Returns LoggedRecord list logs: the list of log messages
GetProgressData
Returns progress data from the Switch Server.
SOAP method GetProgressData
Parameters Integer lastHours: progress data for this number of hours will be returned
Returns ProgressRecord list logs: the progress data
GetStatus
Returns the status of the connection, and some information about the Switch Server.
SOAP method GetStatus
Parameters None
Returns Status list res: a list with exactly one element of type Status
GetSubmitPointName
Returns information about the specified submit point.
SOAP method GetSubmitPointName
Parameters String flowId: the ID of the flow that contains the submit point
String submitPointId: the ID of the submit point
Returns SubmitPointData list submitPointData: a list with exactly one SubmitPointData item
GetSubmitPoints
Returns the list of submit points for a given flow.
SOAP method GetSubmitPoints
Returns String list submitPoints: the IDs of the submit points
GetUserJobs
Get information about jobs currently residing in the Switch Server.
SOAP method GetUserJobs
Parameters Integer hours: any jobs active within this last number of hours will be returned
Integer flags: reserved
Returns UserJob list userJobs: the list of jobs on the Switch Server
PushCheckpointJob
Pushes the specified job to one or more connections.
SOAP method PushCheckpointJob
PushJobStatus jobInfo: the necessary information to push the job to the connection(s)
Returns Integer param-5: reserved
ReplaceFile
Replaces a job in a checkpoint, and pushes the result to one or more outgoing connection(s).
SOAP method ReplaceFile
Parameters ReplaceEntry inEntry: information about the job replacement
Base64Binary inSubmitData: the job to submit; this must be a zip file containing either a single file or a single folder
PushJobStatus jobInfo: the necessary information to push the (replaced) job to the connection(s)
Returns Integer isReplaced: 1 if the job was replaced, 0 if not
SetJobLockStatus
Locks or unlocks a job.
SOAP method SetJobLockStatus
Integer lockStatus: one of the following values: 0: unlock 1: lock 2: solid unlock 3: solid lock
Returns Integer isSet: 1 if set, 0 if not set
SubmitFile10
Submit a job to the specified submit point.
SOAP method SubmitFile10
Parameters SubmitEntry inEntry: information about the job to submit
MetadataToFillClass list metadata: the required metadata
Returns String outJobId: reserved
DownloadReport
If a checkpoint has the Enable report viewing property set to Yes, this method can be used to download the dataset provided in the Report dataset name property.  If Enable report viewing is off, or if the dataset doesn’t exist, this method will fail.
SOAP method DownloadReport
String jobId: the ID of the job whose report you wish to download
Returns Base64Binary inSubmitData: the requested report
