<soap:Body xmlns:butterfly="http://tempuri.org/butterfly.xsd"> <butterfly:GetCheckpointJobInfoResponse> <jobInfo> ... <jobMetadata> <mtdLabel>Metadata Field 1</mtdLabel> <mtdDescription/> <mtdDataType>string</mtdDataType> <mtdValue>hello</mtdValue> </jobMetadata> <jobRequiresMetadata>true</jobRequiresMetadata> <jobRequiredMetadata> <mtfLabel>Metadata Field 2</mtfLabel> <mtfDescription/> <mtfDataType>string</mtfDataType> <mtfDataFormat/> <mtfValueIsRequired>false</mtfValueIsRequired> <mtfRememberLastValue>false</mtfRememberLastValue> <mtfValue/> </jobRequiredMetadata> </jobInfo> </butterfly:GetCheckpointJobInfoResponse> </soap:Body>
Here we can see that there is a display metadata field “Metadata Field 1” with value “hello”, and a second field “Metadata Field 2”, for which we should provide the value. When pushing the job using PushCheckpointJob, we provide the value for this field:
<soap:Body xmlns:butterfly="http://tempuri.org/butterfly.xsd"> <butterfly:PushCheckpointJob> <flowId>7</flowId> <checkPointId>4</checkPointId> <jobId>0006M</jobId> <jobInfo href="#id0"/> </butterfly:PushCheckpointJob> <multiRef id="id0" soapenc:root="0" soap:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/"> <jobRequiredMetadata href="#id1"/> <metadataXmlStr/> <connectionIds>7</connectionIds> <jobName>info.txt</jobName> </multiRef> <multiRef id="id1" soapenc:root="0" soap:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/"> <mtfLabel>Metadata Field 2</mtfLabel> <mtfDescription/> <mtfDataType>string</mtfDataType> <mtfDataFormat/> <mtfValueIsRequired>false</mtfValueIsRequired> <mtfRememberLastValue>false</mtfRememberLastValue> <mtfValue>world</mtfValue> </multiRef> </soap:Body>
