Jobs are a central concept in Switch. Using the Web Service SDK, we can submit, download, replace, lock and unlock, and push (i.e. move to a checkpoint’s connection(s)) jobs.
To send jobs through SOAP, Switch uses DIME, and all attachments must be stored in a zip archive.
<soap:Body xmlns:butterfly="http://tempuri.org/butterfly.xsd"> <butterfly:SubmitFile10> <inEntry href="#id0"/> <inSubmitData href="CE0B4222945833ED125480C7C1D7F25D" xsi:type="xsd:base64Binary"/> </butterfly:SubmitFile10> <multiRef id="id0" soapenc:root="0" soapenv:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xsi:type="butterfly:SubmitEntry" xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/"> <flowId>7</flowId> <submitPointId>1</submitPointId> <jobName>info.txt</jobName> <jobOrigin>/info.txt</jobOrigin> <metadataXmlStr/> </multiRef> </soap:Body>
Where CE0B4222945833ED125480C7C1D7F25D points to a DIME attachment of a zip file.
<soap:Body xmlns:butterfly="http://tempuri.org/butterfly.xsd"> <butterfly:SubmitFile10Response> <outJobId/> </butterfly:SubmitFile10Response> </soap:Body>
Downloading or replacing a job is similar.
<soapenv:Body xmlns:butterfly="http://tempuri.org/butterfly.xsd"> <butterfly:GetCheckpointJobInfo> <flowId>7</flowId> <checkPointId>4</checkPointId> <jobId>0006J</jobId> </butterfly:GetCheckpointJobInfo> </soapenv:Body>
The resulting JobStatus element contains the possible outgoing connections, e.g.:
<soapenv:Body xmlns:butterfly="http://tempuri.org/butterfly.xsd"> <butterfly:GetCheckpointJobInfoResponse> <jobInfo> <jobAllowMultipleOutputs>false</jobAllowMultipleOutputs> <jobEnableReportViewing>false</jobEnableReportViewing> <jobAllowReplacingJob>false</jobAllowReplacingJob> <jobName>info.txt</jobName> <jobReportName/> <fullUserName>bens</fullUserName> <jobSize>52</jobSize> <jobSubmitTime>29.06.2011 15:57:18.967</jobSubmitTime> <jobWaitingTime>30.06.2011 17:29:14.456</jobWaitingTime> <connections> <connectionId>7</connectionId> <connectionName>Folder 2</connectionName> </connections> <jobRequiresMetadata>false</jobRequiresMetadata> </jobInfo> </butterfly:GetCheckpointJobInfoResponse> </soap:Body>
Now we can use these connection IDs to push the job:
<soap:Body xmlns:butterfly="http://tempuri.org/butterfly.xsd"> <butterfly:PushCheckpointJob> <flowId>7</flowId> <checkPointId>4</checkPointId> <jobId>0006J</jobId> <jobInfo href="#id0"/> </butterfly:PushCheckpointJob> <multiRef id="id0" soapenc:root="0" soapenv:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/"> <metadataXmlStr/> <connectionIds>7</connectionIds> <jobName>info.txt</jobName> </multiRef> </soap:Body>
The response is a single, reserved integer:
<soap:Body xmlns:butterfly="http://tempuri.org/butterfly.xsd"> <butterfly:PushCheckpointJobResponse> <param-5>0</param-5> </butterfly:PushCheckpointJobResponse> </soap:Body>
